    Bandcamp streaming, is it still a problem?
      debdeepray last edited by
      I know there had been issues with soundcloud and bandcamp in the near past, but I assumed they were solved. But I noticed today that I am unable to stream tracks at bandcamp, soundloud though is fine. A flash issue?
      Thanks in advance! 🙂
        Just tested it and it works fine here. They don't appear to be using Flash. What version of Opera are you using? Do you have Turbo enabled? What extensions are you running? Have you tried the site in a private window?
          Interesting. I am running the latest version, 31.0.1889.151, the only extensions I am running are the translate and ad blocker. But it doesn't seem to run in private window (no extensions enabled). And turbo is not enabled.
