    Change Speed Dial search engine
      pppoooiuuiuiuzijkghjhbjhbjkugb last edited by
      Hi!
      How do I change the search engine on the Speed Dial page? Or hide the search bar?
        You can hide it in Settings if you have Power User mode enabled. Enable it by typing the Konami Code in the setting screen.
          The Konami code is: up up down down left right left right b a
            aeroxy last edited by
            I have the same question. It wouldn't be such a problem if opera didn't set my engine to a chinese one by default for some reason (it was fine on my other computer so I guess it is random?). I can't even use it (404 error).
