    Recovering bookmarks help
    • H
      hat988 last edited by
      I moved my Opera installation across to another hard drive (just by copying it). This lost all the settings, mail, bookmarks, etc. I logged into Opera Link and found a list of all my bookmarks. Is there a way to actually import those bookmarks into the browser or download the list? My browser version is 12.15 (I only want to upgrade if it is the only way to get my bookmarks).
        Opera Link only works with Opera 12 and older, so updating to more recent version of Opera wont help you. Just an FIY, Link was shut down like 2 years ago, so don't expect it to keep your bookmarks forever. Just open them from inside Link and re-bookmark them.
        I don't remember how to do that in 12, as its been years since I've used it, but its easy to do in 30. Just right click a tab and click 'create speed dial folder' and then use the bookmarks manager to move the folder from your speed dial to your regular bookmarks.
          I reckon if you installed Opera anew in that other place then copied your Profile folder there - it could actually work.
          Otherwise, if you only need your bookmarks but not any settings, you could transport them via the built-in export-import feature - either with a .adr or .html file.
          I don't know much about mail, but your settings must be stored somewhere in (an) .ini file(s) - most probably within that Profile folder it is.
