    Issues running Java 1.7u71 and 1.8u25
    Opera for Linux
      fbscarel last edited by
      Hello all,
      I'm reporting that, similarly to what is happening with Windows version apparently, Opera 12.16-1860-x86_64 is having issues running Java applets when using Oracle JRE 1.7u71 or 1.8u25. Downgrading to JRE 1.7u67 solves the problem completely.
      At first I thought this could be an issue with my kernel version (I'm running these tests on Gentoo-amd64), but looking through the forums quickly solved this doubt.
      For what it's worth, I haven't tested on the new beta 25+ versions. The increased installed size and number of dependencies are unacceptable for the purposes I intend to use the browser for.
        To better illustrate my size/dependency claim:
        ~$ du -sm opera-* | sort -n
        46	    opera-12.16-1860.x86_64.linux
        148	    opera-beta_26.0.1656.8_amd64
        That's after decompression, both files. As for dependencies:
        ~$ ldd opera-12.16-1860.x86_64.linux/lib/opera/opera | wc -l
        23
        ~$ ldd opera-beta_26.0.1656.8_amd64/usr/lib/x86_64-linux-gnu/opera-beta/opera-beta | wc -l
        62
        • Y
          yazdzik last edited by
          Dear friends
          I am running beta, and java seems not to work at all, as in chrome. There appears to be no work-around. I have also observed in opera, firefox et al that the newer java does not work.
          thus, running .65 of 1.7 is the only current alternative.
          Please, opera devs, at least let us know whether there is the same situation here as with chromium.
          Best,
          Martin
            ruario last edited by
            Yes, Java only exists as an NPAPI plug in. As we do not support these, you cannot get Java running.
