    [Solved] Sticky speed dial bookmarks
    solved
    10137
      What email program are you clicking the link in that opens up Opera?
        burnout426 Volunteer @RobHill last edited by
        @robhill said in Sticky speed dial bookmarks:
        Looking more like uninstall and bring in the 64 bit version
        Sounds like a good idea.
        Then, if that alone doesn't fix things, you can do some testing with a new Opera profile.
        Try this with your good Opera session:
        • Back up your open tabs. Right-click on the tab bar and choose "save all tabs to speed dial folder" or right-click on a tab, goto "save" and choose "all tabs to a speed dial folder. If you use workspaces, do this for each workspace.
        • Back up your bookmarks and speed dials. Goto the URL opera://bookmarks and use the drop-down at the bottom left to export your bookmarks to an HTML file named "operabookmarks.html".
        • Goto URL opera://settings/passwords, click the 3 vertical dots to the right of "saved passwords" and choose to export your passwords to a csv file named "operapasswords.csv".
        • Close Opera and rename the "Opera Stable" folders in "C:\Users\rob\AppData\Roaming\Opera Software" and "C:\Users\rob\AppData\Local\Opera Software" to "Opera Stable Backup".
        • Start Opera (directly). It will create a fresh profile.
        • Goto the URL opera://flags/#PasswordImport, enable the import flag, and restart Opera.
        • Goto the URL opera://settings/passwords, click the 3 vertical dots to the right of "saved passwords" and choose to import the operapasswords.csv file you previously exported.
        • Goto the URL opera://settings/importData, select "Bookmarks HTML" in the drop-down and choose to import operabookmarks.html that you previously exported.
        • Goto the URL opera://startpage (the speed dial page), right-click on the folder you created with "save all tabs to speed dial folder" and choose "open all in tabs". If you make use of workspaces, make sure to recreate the missing workspaces and then use "open all in tabs" for each extra speed dial folder you previously created while being in the corresponding workspace.
          R 2 Replies Last reply
          RobHill @burnout426 last edited by
          @burnout426 Aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaagggggghhhhhhhhhhhhhhhhhh!!
          I have run the uninstall 4 times and it won't go. The progress bar gets to about 90% and the progress pop up disappears and everything is still there in the apps list (v.256 - 21/7) and in Program files (x856)
          How do I get rid of it?
          About to throw laptop out of the window!
            @burnout426 - Hi - have also checked the registry - only the one X86 entry. HAve tried uninstall again - a few times - still not working. Still on version .256 even after a couple of attempts it did on its own to update to .277.
              To uninstall Opera, you can just delete its program files folder. So, delete "C:\Program Files (x86)\Opera".
              To get rid of the entry (or entries) for it, you can manually delete the keys in the registry.
              Opera's install entries are in "HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall" or "HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" depending on the type of install. You can look in "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" too, but there probably won't be any Opera keys there.
              If you want to go further, you can delete the Opera keys under/in:
              "HKEY_LOCAL_MACHINE\SOFTWARE\Clients\StartMenuInternet"
              "HKEY_CURRENT_USER\SOFTWARE\Clients\StartMenuInternet"
              "HKEY_CURRENT_USER\SOFTWARE\Classes"
              "HKEY_LOCAL_MACHINE\SOFTWARE\Classes"
              "HKEY_CLASSES_ROOT"
              And, you can delete "HKEY_CURRENT_USER\SOFTWARE\Opera Software".
              And, you can delete any Opera strings in "HKEY_CURRENT_USER\SOFTWARE\RegisteredApplications" and "HKEY_LOCAL_MACHINE\SOFTWARE\RegisteredApplications"
                burnout426 Volunteer @burnout426 last edited by
                You can also delete everything in "C:\Users\rob\AppData\Local\temp" and "C:\Windows\temp" (or at least delete all Opera-related temporary files and folders).
                And, then, you can delete any Opera shortcuts, pinned taskbar buttons and start menu items.
                  And, ideally, if you don't mind starting completely over, you could also delete your Opera profile and cache folder, and loose everything so that Opera creates a new profile. That will ensure there's no profile corruption. (Previously though, I showed you how to back up some stuff, create a new profile, and import some stuff back, so that you don't lose everything.)
                    @burnout426 Hi - thanks for all that info. I did do the backup steps you gave earlier so hopefully I can get rid of the old 32bit version, install the latest 64bit and import my old data and all will be well. Will have a go later. Thanks again for your very detailed help
                      @burnout426 Hi- Thanks folks for all the help. I now have the 64bit version installed and using my old data etc. Thanks again
                        @robhill Are things better when you click on a link in an email too?
                          R 1 Reply Last reply
                          @burnout426 Yep - all working perfectly. Thanks to everyone for all the help
