    Collection "edge" variation, Flow is not solution
    flow workspace bookmarks
      Problem: 2GB ram of simultaneusly opened webpages even different workspaces (are opened and consume resources and actually are only "new" web browser).
      Between lines: Edge's collection can be deal breaker with Opera.
      Sollution Feature requested: Since we all need short term webpage workspace(real not one introduced in Opera earlier)
      Workflow: Save links, Save images(with source link), text with (annotation - web link), feed in custom text notes, custom images from PC.
      Open it all on mobile app.
      Export it for further formatting to some text editor. or directly send with email and than easily delete that work-space.
      Sample of workflow: You need to make a small research for your boss, 10 web links, 4 annotations, conclusion... and send it. Parallel finish other research you started yesterday. (need to work parallel)
      But FLOW argument: Flow can't substitute, because you can work on 2-3 such tasks simultaneously and FLOW is a streamlined flow that can't go parallel. Also you cant rearrange content in Flow.
      Feature requested: Use tab to create in FLOW parallel workspace like "edge" 😉 easy, done, and rename workspaces to instance or sth else because it is not a workspace it is only a parallel web browser you can transfer webpages across nothing more.
