    Problem: Strange visual errors frequently appearing
      As the title would suggest, I have experienced many strange visual problems since switching over to GX (I switched because Chrome was using too much RAM and I liked the ability to limit RAM use on GX) but this is just as, if not more annoying. Below is an example of the visual issues I've been facing. Does anyone know a solution to this?
        sometimes when i'm using opera GX, some parts of the screen turns to a mix of RBG coloursrgb.png
          NoviFlow last edited by
          I've the same problem but i'm using just Opera, not Opera GX. I think it's a problem with the last update, because I use Opera for more than one year now and it's the first time I've this issue.
