    Problems with Magnet Links
    12
    12414
      cbentley last edited by
      I'm currently having a problem opening magnet links in my Opera browser. I'm using Opera 18 on Windows 8 64bit, and my magnet links work in every other browser just not Opera. Is there anything I can do to remedy this?
        freddie2014 last edited by
        Hi cbentley
        Its really simple just go to
        C:\Users\"username"\AppData\Roaming\Opera Software\Opera Stable\
        and open your "Local State" file with e.g. notepad and add: "magnet": false, to the "excluded_schemes" section
        Be sure to flag: false ๐Ÿ˜‰
        Like this:
        "protocol_handler": {
        "excluded_schemes": {
        "afp": true,
        "magnet": false,
        "data": true,
        "disk": true,
        "disks": true,
        tested and wrking on opera 18 and 19
        Hope it works for ya
          lukasmilan last edited by
          Thanks Freddie...
          Suprisingly Iยดve managed it myself by your manual. And it works!!! ๐Ÿ˜ƒ
          Windows 8.1 (64bit), Opera 19.0.
          Finally I can rid of Mozilla...
            kaidrazer last edited by
            Hi there,
            I have the same problem like akagi211 and i have modified the local state file as you described but now when i click on the magnet link nothing happens. There is no response at all.
            What should i do?
              I'm using Opera 64bit v.28.0.1750.51
                There's no Opera 64 bits.
                I don't think there is a way to fix it atm. Associating magnet links with a program may help.
                  When I try to associate the magnet links with a program I get a blank window with no options.
                    So you don't have any program that can handle those links?
                    If you have, can you do the association from inside the program?
                      I did the association from BitTorrent and it works now. Thank you!
                        einherjar101 last edited by
                        Ok I have the same issue but am unable to find the "Local State" file. In C:\Users"username"\AppData\Roaming\Opera Software\Opera Stable\ I have only 2 folders:Cache and Media Cache.
                        I have hidden files enabled and have Opera 29.0.1795.60 installed.
                        Any advice would be welcome.
                          Then your install has issues. You should have close to 2 dozen folders and twice that many files in that directory.
                            So basically I should do a reinstall of opera?
