    Problem logging into dropbox
    10
    4262
      jjjjjjjj123 last edited by
      Hi all,
      I am having problems to log into dropbox.com with Opera. I have doublechecked the password but I get the message "There was a problem completing this request." Anybody else experiencing this?
      I have reset the saved password, changed dropbox password but did not succeed.
      Logging on with Chrome or IE works fine.
        Try it in a private window. Does that work?
          Yes it works in a private window. How come? What do I need to do to make signing in possible in a normal window?
            Private windows disable your extensions by default. So one of your extensions is probably the source of the issue. Disable them all and turn them on one by one until it breaks. This should allow you to track down the one causing the problem.
              bashour last edited by
              I have exactly the same problem
              If you solved it doing the above what was the problem extension
                As different users have different extensions installed, I guess you will have to find by yourself since it may be a different one causing the issue for you.
                Just do as explained, it doesn't take much time.
                  tuoppi42 last edited by
                  I have same problem, can not login to dropbox from Opera. I have no extensions installed, just installed Opera. Private window works, so it seems that extensions it not a problem?
                    scorpions89 last edited by
                    A year later and the issue is still present. No one bothered to fix it? Still accessible from private window. All extensions, ad-blocker etc disabled but nothing. Latest release of opera.
                      Probably there is nothing to be fixed?
                      This mean that an extension may be causing the issue or perhaps a broken profile.
                        vayth last edited by
                        I just fresh install Opera and has no other extension, yet this happens.
                        That means it must some "extension" built-in the opera, right? Any hints on how to tackle this problem?
                        VPN is off, turbo is off, and -although I think it's relevant- I also whitelist dropbox in AdBlocker.
