Discussion thread
Why doesn't "Create Search Engine..." (in Context Menu) appear everywhere it should?
raspythroat
raspythroat
    Why doesn't "Create Search Engine..." (when you right-click on a search box) appear when it should?
    It does not appear in http://web.archive.org/. Happily, "Create Search Engine..." appears in https://web.archive.org/web/20170807102201/http://www.fsf.org/
    Why doesn't it appear in the former?
    Version information
    Version: 46.0.2597.57 - Opera is up to date Update stream: Stable System: Linux Mint 18.2 (x86_64; XFCE)
    9 Replies - 167 Views
    jimunderscorep
    0 0
    jimunderscorep
      It does appear for me (opera stable 46 on debian testing x64).
      raspythroat
      0 0
      raspythroat
        jim_p, screenshot please :)
        Sincerely, raspynounderscorethroat
        sgunhouse
        0 0
        sgunhouse
        • Moderator
        • Server monkey
        • 2000 posts
        It's available in the Search box in the corner, not where you indicated.
        jimunderscorep
        0 0
        jimunderscorep
          My bad, I checked it on archive.org, not on WEB.archive.org. As seen on the pics here, the search box on web.archive.org did not allow me to create a search engine
          https://imgur.com/a/u9lU
          raspythroat
          0 0
          raspythroat
            Why not? Software should make it easy for humans. We humans shouldn't have to work around software.
            sgunhouse
            0 0
            sgunhouse
            • Moderator
            • Server monkey
            • 2000 posts
            Ask them. Opera can only look at the page and see if something looks like a search field.
            jimunderscorep
            0 0
            jimunderscorep
              I also made a wrong paste of the imgur link! Here is the right one
              https://imgur.com/a/u9lUC
              raspythroat
              0 0
              raspythroat
                thanks, Jim_P.
                First two have the "Create Search Engine" option. The third doesn't.
                jimunderscorep
                0 0
                jimunderscorep
                  Yes, thats why I posted 3 screenshots. The search box on WEB.archive.org is the one that lacks the "create search engine" option, the other 2 have it as expected.
