    How to post about a problem with Opera Mini
    Opera Mini
      If you would like to post about a issue you are facing in Opera, please make sure to include the following information as it will help other people in trying to check the problem and help you.
      • Topic title/subject (if you are opening a new one): It should be a short summary of the problem. Example: 'Can't play video on site xyz' or 'Opera crashes if I open settings page'
      • Use one topic per issue unless they are related. Many issues being discussed on the same topic may confuse people.
      In the topic body, include the following:
      • Description: Here you will describe what the problem is with the most details as possible but being objective and concise.
      • Steps to reproduce: Here you will show what people should do to try to reproduce the problem. Example: Go to page zyx; click on 'this', etc
      • Actual result: What do you see, what happens when you do the steps you have listed above
      • Expected result: What should be the correct behaviour when performing those steps
      • OS: Your phone's OS
      • Phone model: Your phone model (Samsung S7, Sony Xperia Z3, Iphone, Nokia, etc)
      • Country and ISP (Internet Service Provider): The country you are in and your ISP.
      • Data saving mode: If you are using High or Extreme mode
      • URL: If the problem is with a page, post its address here
      • Version of Opera: What Opera Mini version you are using
