    "Use bitmap fonts for complex scripts" setting can't be found
    Opera for Android
    15083
      I can't find the setting "Use bitmap fonts for complex scripts" in the new update. Please tell me how to enable this. Thanks in advance.
        You didn't find that in the previous update either. Bitmap fonts can be enabled in Opera Mini via opera:config.
          I actually did find and activate it in the previous version. I can't remember the code to enter into the address bar now. about:config returns a blank page. Please help.
            Maybe you are talking about Opera Classic?
            I don't remember this option in Opera Blink.
              No. I'm talking about Opera Mobile browser for android. It was there in both mobile browser and mini browser.
                In which version of Opera for Android?
                  In the previous version. Must be v28.
                    I will check that.
                      Please let me know the correct code to enter into the address bar to enable that setting. Thanks in advance.
                        vigneshlin last edited by
                        it worked in off road not in turbo mode.
                        and also it works in opera mini and not in opera mobile classic browser
                          It worked in both modes and both browsers! I used that feature. I can't find the setting with this new update.
                            Maybe it was a flag, now removed?
                              No idea. Doesn't anybody know?
                                previous version which has off road mode has config: menu... use that one turbo mode version don't support it
                                  install older version of u want to use bitmap option
                                    Oh is that so? Then can I please know how to make a feature request?
                                      emoller last edited by
                                      Hi nishadrox that is a feature of the Opera Mini client... which was also available in OffRoad mode. We've moved away from OffRoad mode in Opera for Android because of its many other issues. Not that I'd like to see you go, but if you only want to use OffRoad mode then the new Opera Mini is the app for you.
                                        I assume you are talking about the "Use bitmap fonts for
                                        complex scripts" setting. Are you sure the new Opera for Android doesn't have this feature?
                                          Yes I am sure. You access it through typing opera:config in the url bar. You can do that both in the old and the new mini, but it's not a feature of Opera for Android (post version 28).
                                            shojeeb911 last edited by
                                            Open Opera mini and write opera:config on the address input bar.Hit the ok/go button and load the page to go on power user setting, Now after loading the page, scroll down. And you can see an option named Use Bitmap fonts for complex scripts.
                                            check yes and click on save button if you need help with screebshot that you may try this opera config bangla and all bitmap step by step with screenshot
                                            thank you.
