    Tap to zoom, Flash plug-in, when?
    Opera for Android
    • iPristy
      iPristy last edited by
      Tap to zoom?
      Flash plug-in?
      If this two things would work, than i would not need to use FF anymore.
      FF got some issues too but they are not that severe as Opera.
      • thedicemaster
        thedicemaster last edited by
        double-tap zooming works fine, but some mobile pages block it.
        flash plugin will never be supported because it doesn't work at all on any newer devices(android 4.4+)
        even if the browser has support for flash, it just can't see flash.
        • iPristy
          I got 4.1.1 Android, and double-tap to zoom stop working with Opera 19.
          If not a bug or something else, well that's that.
          FF can't do about anything but Flash, smart zoom works just fine.
          • iPristy
            The point that am trying to make is that some pages look smaller in Opera than on FF and can't double tap to zoom on this page in Opera, but it works in FF.
            If HiDPI is doing something wrong don't know, you are the expert.
