Opera 52: Flash will not work on BBC News
  • Link works fine here video plays
    Thats all i can add
  • @leocg will I loose all my bookmarks if I uninstall and reinstall?
  • @vincej1657 Only if you choose to remove your data.
    Anyway, you should always do a backup.
  • @vincej1657
    Confirm. I have this problem too. It's happens after last opera update.
    I was fix it by disable hardware acceleration in settings.
    But i think it's not right, because now I have freezes in flash videos.
    If hardware acceleration is enabled - i hear sound, but I see black screen instead of video.
    I'm was try to update and reinstall flash player, but it don't help me.
  • @acmanich Could you give more details on your system
    if disabling hardware accel "fixes it" It may be bad drivers
    [graphics] hard to say without more info
  • @leocg It looks like someone else has the same problem.
  • @vincej1657 check this in opera settings
    Then try this
    If you see this, means ya took to long to do step 1 & 2
    just reload page again and repeat step 1 & 2... except do it a lil faster..
  • @nvmjustagirl Thank you for your detailed answer. From the outset, I have allowed Flash to run on sites. Your intermediate step "Click to enable Adobe ...." does not exist on my PC. It goes immediately to "Sorry you need Flash ... "
    I have done to the link provided and downloaded Flash. I am assuming that it was installed into the correct place. How can I check if it is installed correctly?
  • @vincej1657
    Flash Player is coded to install to -
    C:\Windows\System32\Macromed\Flash (on 32-bit systems)
    C:\Windows\SysWOW64\Macromed\Flash (64-bit systems)
    File name in flash folder called - FlashUtil32_28_0_0_161_pepper.exe
    Mines probally older version.. but still works with BBC.com
  • To test to see if you can at least get Flash running in a fresh, test Opera:
    Download the Opera installer, launch it, click "options", set "install path" to a folder on your desktop, set "install for" to "standalone installation" and install. In that Opera, goto "Menu -> settings -> Websites -> Flash" and set Flash to "Allow sites to run Flash". Don't enable Opera Sync in this test Opera.
    If that doesn't work, in settings in that test Opera, goto "Browser -> System" and uncheck "Use hardware acceleration when available" and restart that Opera to see if it helps.
    If you're not certain you have Flash for Opera, goto https://get.adobe.com/flashplayer/ in Opera, uncheck "download Chrome" (and any other offers), click "install now" to download the installer, launch the installer, close Opera, install Flash and start the test Opera back up again and test some sites.
    If it still doesn't work in the test Opera, you should look for something outside of Opera causing the problem.
  • @ceedee
    Thanks for help. Ok. I have:
    Hardware:
    Notebook HP PAVILION dv6-6b57er
    CPU Core i7 2670QM 2200 Mhz
    GPU Intel HD Graphics 3000 + ATI Radeon HD 6770М
    OS: Windows 7 (64bit)
    Opera: 52.0.2871.40
    I have problems with flash videos after last update of opera. When I click play on video player I hear sound and don't see video, only black screen.
    I was try fully uninstallation of flash player following that instructions:
    https://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html
    Next I was install flash player 29 again. Problem wasn't solved.
    Next I was full uninstall flash player 29 and try version 28 from archives. No effect.
    I was rollback to flash 29.
    I was disable everything installed extentions. It wasn't helps me.
    I was try to enable flash in settings and add sites, where I watching video, in exceptions with Allow param. That wasn't solve my problem.
    I was check driver updates for my video cards by windows control panel (drivers are actual) and was looking for driver updates on hp.com - nothing new.
    In other browsers:
    Google Chrome 65.0.3325.181 - Sound: OK, Video: black screen.
    I was trying fresh version of Yandex Browser 18.3.1.1124 - Sound: OK, Video: OK.
    UPD:
    On some pages I see message about plugin blocking:
    What I want do next? I want to create backup of opera, then uninstall she and install it again.
  • @acmanich I am relatively new to opera myself so will avoid giving any potentially bad advice. I am sure someone more knowledgeable will come along to assist. patience is worth it as opera is a standout browser imho and worth persevering with .
  • @acmanich said in Opera 52: Flash will not work on BBC News:
    I see there's a final driver version for your ATI/AMD GPU here. Page says the driver is beta quality though. It's up to you if you want to try it. I don't know if it's buggy or not.
    For the Intel GPU, this should be the latest. You can compare with the properties in the device manager to see what version you have. These are generic drivers for the HD3000. They should work fine. But, if you find them lacking some functionality for your laptop, you can go back to the Microsoft or HP-provided one.
    See https://forums.opera.com/post/143700.
  • @burnout426
    You help me! Thank you. After drivers installation videos with video again 🙂
    @Ceedee
    Thank you too!
    Trouble:
    Reciept:
    Update your video drivers.
  • @vincej1657 did ya figure out what directory your pepper flash (aka PPAPI) is nstalled in..
    it should be in both of these dir if you're run 'n 64 bit..
  • @acmanich Is the GPU Intel HD Graphics 3000 + ATI Radeon HD 6770М a switchable graphic.. if so and ya got the AMD Catalyst Software go in there and set opera to use Amd card. *might help..
    also since ya down loaded that intel driver .. check The AMD Catalyst under the power tab to see if you're still swichable or if part of it is grayed out now..
  • @nvmjustagirl Yes, it is in the correct 64 bit directory
  • @vincej1657 so is flash work 'n ok..
