IS VPN with problem now?
  • @hger agree! this trick works 🙂
  • even when the VPN issue is resolved, while downloading files the old issue of network interrupted issue is still there. Downloads get stopped after a few seconds.
  • Just done the update to V49.0.2725.56. When using the VPN I now find the choice is limited to Americas or Europe whereas it used to have 6 specific countries. Is this a so called upgrade to a degraded option in this new version. Is there any way to restore the previous 6 specific counties
  • @alanchippy Nope. The new VPN uses regions instead of countries.
  • More dumbing down it seems. I wonder why they have decided on the downgrade.
  • @alanchippy It's not in the dumbing-down category. Opera has simply elected to operate new VPN servers, following it's sale of its SurfEasy VPN subsidiary back in September. The departure of SurfEasy's network of VPN servers means Opera has to arrange and operate other ones, along with the browser updates to accomplish connection with them.
  • Thanks for the post which does explain the reason. It is however still a downgrade in terms of performance and choice even if it was a necessary change. Guess I will have to find a paid for VPN which does what I need now. Can't complain as the Opera VPN was free and worked very well except for the last week or so which presumably was due to the change of servers.
  • @alanchippy said in IS VPN with problem now?:
    if you're going to use another vpn grab the free version of browsec. no bandwidth throttling.
  • Anyone else noticed getting bounced from server to server, it can be as often as every 30-60 seconds or 10 minutes.
    Even on this forum, i'm getting messages saying connection to site lost flashing up at bottom right.
    Europe and Americas both do the same.
    I'm using opera-beta........since i can't get openload.co and vidto.me videos to work (they only stopped working in the last few days) But the VPN in opera-stable is just as bad for stability.
    Most times it gets reconnected within 10 seconds, last night it was just getting stuck on trying to connect.
    Load balancing gone nutts? or overcrowding?
  • Yes the last couple days Opera VPN hasn't had the best stability.
    This does seem to happen on occasion.
  • Thanks for that tip. I will look into it shortly (Wife just come out of hospital after hip replacement so time is a bit limited.
  • Just tried a download using both VPN regions and max speed is 1.2Mb/s on an 80Mb/s Fibre connection. Turning off the VPN during the download results in 79Mb/s. VPN problem it seems as it was OK yesterday.
  • @reshmaraj agree. its very slow too.
    today vpn is not useful again 😞
  • @gloewa may be they are doing the last minute checks on VPN .hope it comes back ok soon.
  • Still the same today, worse than useless with max download speed is 1.3Mb/s and frequent disconnections only when using the VPN.
  • as of yesterday i completely gave up on the built in vpn. did my own test and with built in just over 10mbps and with browsec full speed 125mbps.
  • 45-20 kbps unreal to use it
    few days ago it was so fine
  • Still the same today. Completely unusable.
  • Opera, what are you doing? The 49 version of VPN worked perfectly. Now the download speed with VPN enabled is not even 2MGB. Well, the mockery does not load anything. I have a browser Opera next as a second, through it 'sit' with a VPN (I am so comfortable), and then on you VPN has changed. No choice of countries, only Europe and America. But not that, not that does not work. Only upsets my traffic. If now V50 version 2 mgb, earlier in the 49 version was the choice of countries and everything worked well, the traffic of course the VPN took away, but there were at least 50-60 mgb. Everything with VPN loaded quickly. Now i is forced to delete, opera next for I do not need such a VPN, which is impossible to use. Please return normal VPN functionality to opera next.
  • I call it by name: VPN-functionality is unusable since days. when will it be fixed?
    (@opera-team: don't promote it when it does not work) ☹
