Flash Player and zoom in Win 7 system
janger2 last edited by
Try disabling the ad-blocker.
Flash Player at a scale of 100 % works on all Opera.
Disables the ad-bloker, did not help !Flash Player at a scale of > 100 % does not reveal the entire screen !
Well, it helped for me.
In Opera_Stabl 38.0.2220.31 Flash Player works fine with ad-blocker.
A further 38.0.2220.41 Flash Player does not work .
In Opera_beta and Opera Developer since 37,38,39,40,41 - Flash Player does not work.
Earlier versions of the browser work well with Flash Player. And ad-blocker does not interfere with work.
Here is the problem : -
In Yandex Browser we decided this task - - browser://flags/ #enable-125-hidpi !!!!!
"Activating the zoom 125 % Windows
Set content scaling size according to the scaling factor of 125 % default"And in the Opera when it is solved the problem ?
It helps if you add in the label Opera : --alt-high-dpi-setting = 100 so that Opera was as if not larger DPI.
It helps to break the current eye can be - such fine print at 100 % !
Generally up to 110% of all right , but 125 % is no longer unfolds !
Incidentally, I timed text height at 100 % - about 2 mm, and at 150 % of about 3 mm and the screen 22 is ' ! -
Excuse me.
100% = 96 DPI,
125% = 120 DPI,
150% = 144 DPI,
in --alt-high-dpi-setting = prescribed DPI, not%.
I have in Win 7 is set to 150% -
IT Professionals? ))))))) Software developers need to know about working with high DPI Windows 7 !!!!!
https://msdn.microsoft.com/en-us/library/dn469266(v=vs.85).aspx . Read - "Writing DPI-Aware Desktop and Win32 Applications" -
Flash Player in Opera Developer 42.0.2392.0 stopped open video on the site. http://ren.tv/novosti/2016-10-30/pervoe-video-novogo-moshchnogo-zemletryaseniya-v-centre-italii .
This plus the fact that Opera does not open in full screen, as described above. -
If the opera: // plugins to disable Adobe Flash Player, the video on the site will show http://ren.tv/novosti/2016-10-30/pervoe-video-novogo-moshchnogo-zemletryaseniya-v-centre-italii (in Opera Developer 42.0.2392.0 )!
What sort of tricks? -
We hope that the new owners fired the developers involved in the processing of video Opera. And Flash will work just as well as the on Chrome.
This solution to the problem? -
Stable(41.0.2353.69 - 22.11.2016),Beta(42.0.2393.38 - 16.11.2016),Developer(43.0.2420.0 - 22.11.2016)
Flash Player does not open a full screen when in WIN 7 Ratio> 100 % . I have in Win 7 is set to 150%= 144 DPI.
example:
https://my-hit.org/film/419506/
http://bigbangtv.ru/video/10_season/s10e08.php
http://seasonvar.ru/serial-114-Mrtvie_kak_ya-2-season.htmlWhen the fix?
P.S. In OperaStabl 38.0.2220.31 Flash Player works fine.Log Messages
[1122/190536:ERROR:mf_helpers.cc(12)] : Error in dxva_video_decode_accelerator_win.cc on line 345
[1122/190548:ERROR:mf_helpers.cc(12)] : Error in dxva_video_decode_accelerator_win.cc on line 345
[1122/190617:ERROR:mf_helpers.cc(12)] : Error in dxva_video_decode_accelerator_win.cc on line 345
[1122/190629:ERROR:mf_helpers.cc(12)] : Error in dxva_video_decode_accelerator_win.cc on line 345
