speed dial disappeared
  • open a new tab,
    Click the heart icon on the left of the screen (bookmark),
    When a window appears, click on "OTHER SPEED DIAL"
    Explore the folders that matches your previous speed dial settings. Oh, try to find a way to navigate on the right screen, not on the left, somehow when you try to navigate on the left side it does not show.
    when you found the matching speed dial setting... select all, copy and paste it in the main speed dial..
    Somehow this works so far. I dont know about the add-ons, maybe just re install them...
  • It works for some time, but later on, I have to open the bookmarks to get the old speed dials back.
  • @malek2015 The reason is simple and it surprises me how many people don't understand the question.
    This is the correct answer
    Speed dial uses a cookie and when you do a clean up with another program the cookies are removed and so it defaults back to the basic settings or even asks you to rejoin .
    Thats it, find the cookie put it on the white list and your done.
