Discussion thread
[Solved] Speed Dial Background
browzer1
browzer1
  • Server monkey
Is it possible to set the Speed Dial background (wallpaper) to a solid color? In my case, light blue.
I know it was possible some versions ago but that capability seems to have disappeared. I wish someone would develop wallpapers with just solid colors.
If it is possible, could someone point me to the necessary instructions please.
6 Replies - 151 Views
operafanuk
0 0
operafanuk
    Try checking wallpapers in Opera Add-ons, find one then add it to Opera. Then go to settings and choose desired wallpaper.
    Or find the wallpaper you're after, and copy it into "themes_backup"
    Check this link to my closed thread which addresses this, and which worked for me.
    leocg
    0 0
    leocg
    • Moderator
    • 10000 posts
    You should be able to set any image as theme, so just find one that fits your needs and use it.
    browzer1
    0 0
    browzer1
    • Server monkey
    leo ... how?
    sgunhouse
    0 0
    sgunhouse
    • Moderator
    • Server monkey
    • 2000 posts
    Right-click on image > Use image as wallpaper
    leocg
    0 0
    leocg
    • Moderator
    • 10000 posts
    Or right click on Start Page /Speed Dial > change wallpaper > click on the plus button.
    browzer1
    0 0
    browzer1
    • Server monkey
    Thanks to all that replied. I found a color (image) and dragged and dropped it. Works perfectly.
    This discussion has been closed.
