Discussion thread
How to copy and paste cookies file in opera portable for use with different system.
zaitsev
zaitsev
    After i install opera portable then i edited cookies with extension. I try copied this folder opera portable into usb drive and paste this folder to another pc of laptops. But not work, cookies data that i setup at once disappear when check with extension.
    I know that, i should use extension to import and export cookie data but i want to know why copy and paste not work. It'possible to copy and paste instead import and export cookies.
    3 Replies - 49 Views
    leocg
    0 0
    leocg
    • Moderator
    • 10000 posts
    What exactly did you do? What extension did you use?
    I've copied the Cookies file from one Opera installation to another - in the same computer - and it seems to have worked fine.
    sgunhouse
    0 0
    sgunhouse
    • Moderator
    • Server monkey
    • 2000 posts
    Cookies, like passwords, are encrypted to the user account and will not work for another user account nor on a different PC. Sorry, can't be done.
    leocg
    0 0
    leocg
    • Moderator
    • 10000 posts
    Didn't know that.
