Discussion thread
Opera does not work on MANY sites
geoffreylevens
geoffreylevens
    I have Opera 44.0 on a 2102 Airbook. On many sites it does not work! Much worse than even Safari. Sites don't fully load, formatting of pages messed up, hotlinks and buttons don't work. Is this just "the way it is"?
    2 Replies - 64 Views
    zalex108
    0 0
    zalex108
    • Server monkey
    • 1000 posts
    Read and try this
    avl
    0 0
    avl
    • Opera employee
    • Moderator
    Hi @geoffreylevens,
    Do you have Opera Turbo turned on (Menu: Opera -> Opera Turbo)? If so, turn it off. It's only beneficial on very slow internet connections, and might slow you down or cause problems when you're on a fast internet connection.
    If you don't, tell us a bit more about one site where you see the problem, and we can probably check what's happening.
    No.
