Forums will be closed soon as read-only due to our ongoing migration to the new forums page!
Discussion thread
How to post about a problem in Opera
leocg
leocg
  • Moderator
  • 10000 posts
If you would like to post about a issue you are facing in Opera, please make sure to include the following information as it will help other people in trying to check the problem and help you.
  • Topic title/subject (if you are opening a new one): It should be a short summary of the problem. Example: 'Can't play video on site xyz' or 'Opera crashes if I open settings page'
In the topic body, include the following:
  • Description: Here you will describe what the problem is with the most details as possible but being objective and concise.
  • Steps to reproduce: Here you will show what people should do to try to reproduce the problem. Example: Go to page zyx; click on 'this', etc
  • Actual result: What do you see, what happens when you do the steps you have listed above
  • Expected result: What should be the correct behaviour when performing those steps
  • OS: Your *nix distro/version
  • URL: If the problem is with a page, post its address here
  • Version of Opera: What Opera version you are using
This discussion has been closed.
